Partager |
 regulateur tension pour f3k - PLD-BAC-004
Aller à la page : 1, 2, 3, 4, 5, 6  Suivant
maume gilles
Nombre de messages: 398
MessageSujet: regulateur tension pour f3k - PLD-BAC-004   Mer 20 Jan - 22:21
Quelqu'un aurait il un retour d'experience sur regulateur de tension suivant: PLD-BAC-004 ?
Est il capable d'alimenter les 4 servos d'un f3k , 2 D47 ET 2 DS 281.
Merci,
Gilles
http://www.hyperflight.co.uk/products.asp?code=PLD%2DBAC%2D004
Use the LiPo Regulator & Alarm to reduce the weight of your glider and allow you to fly longer by safely replacing the NiMH receiver pack with a lighter, but higher capacity LiPo battery.
Specifically designed for discus launch gliders (DLGs), the PLD-BAC-004 (BEC Alarm Combo) has been made as small as possible but still packed with needed functionality.
This updated and improved version replaced the original PLD-BAC-001. The 004 version now includes a built in LED for voltage level indication as well as an audio alarm for when things get to the critical stage. The LED flashes the voltage level, so if the battery is 7.2V it will flash 7 times, pause and flash twice more. Also the PLD-BAC-004 has an improved circuit design to give less voltage sagging and lower noise on the signal and power wires.
  • Very low weight - 5.75g
  • Very small - 19 x 12.5 x 10mm
  • 2S lipo input.
  • 5V output.
  • LED voltage indicator, flashes the voltage digit, then pauses, then flashes the voltage decimal. After a longer pause the voltage flashes are repeated, continually.
  • Over voltage alarm (battery more than 8.5V).
  • Under voltage alarm (battery less than 7.0V).
  • Buzzer alarm.
  • 1A linear BEC for minimum RF interference.
  • Extensive decoupling for even quieter RF levels.
  • 250mA constant supply, 500mA for 1 minute, 1A for 10 seconds (thermally limited - better cooling gives longer duration).
  • Thermal and short circuit protection.
  • High quality, low power, low (RF) noise micro controller.
  • Large copper backplane to improve heat-sinking of linear regulator.
  • Supplied with 50mm RX lead and 100mm JST battery lead.
  • Covered with heatshrink for protection against accidental shorts and sharps damage.
The red JST plug should be connected to the LiPo battery , and the R/C plug is inserted into a spare receiver channel.
jf dufourg
Nombre de messages: 86
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Mer 20 Jan - 23:26
Salut Gilles
Fais une recherche sur le site avec "régulateur de tension" tu trouveras pas mal d'info...
Ce que je peux te dire c'est qu"avec un régulateur 5v (SFC 2805Ec - 3grs) acheté 0.8€ dans un magasin d'electronique , cela pèse 2grs
En entrée tu mets de 5v à 20 v et t'as du 5v régulier en sortie pour 4 servos sans pb...
Hyper léger ;pas cher; 3 soudures à l"étain...je voie pas pourquoi aller chercher autre chose...
Mais bon les gouts et les couleurs...
JF
Erik Richards
Nombre de messages: 739
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Jeu 21 Jan - 8:47
Moi j'utilise la version à leds depuis une année sans coucis sur 3 F3k avec 4 servos (2 d47 et 2 HP-DS09-SCD) http://nqrc.com/?vp=PLD-BAC-LED
Simplement parceque pour le meme poids que ton montage il y a en plus le controle de la tension de la batterie, en fonctionnement vert>bon, rouge>pas bon mais ca ne sert à rien tant que le planeur vol... le plus interessant c'est qund on branche la battereie il indique le niveau de la baterie avec la led rouge, clignote une fois>battereie plein, clignote cinque fois>batterie quasi vide. Quand on a déja eu des coucis de baterie la tranquilité d'esprit lors d'une manche ca n'a pas de prix.
Mais bon les gouts et les couleurs... Wink
Erik
Serge Delarbre
Nombre de messages: 179
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Jeu 21 Jan - 10:08
jf dufourg a écrit:
Salut Gilles
JF
Pourquoi aller chercher autre chose ? Simplement parce que :
la référence de composant que tu cites est en voie d'obsolescence (mais il y a des équivalences : MC7805 par exemple).
Le drop out de ce type de composant est de 2V typique. C'est-à-dire que pour que la régulation à 5V soit effective, il faut en entrée 5+2V = 7V. Cela limite fortement leur plage d'utilisation : en 2S seuls les LiPos sont compatibles, exit les Life à 6.6V nominal. Et pour du NiMh, il faut du 6S (7.2V nominal) rédhibitoire en F3K.
Erik Richards
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Jeu 21 Jan - 11:03
Moi j'attends avec impatience que greentronic nous sorte quelquechose de similaire pour le F3K Razz
Ou encore mieux, il faudrait que les fabricants de servos nous fassent des servos de F3K qui ne grillent pas sous 7.4v Suspect
Serge Delarbre
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Jeu 21 Jan - 11:21
Je vais leur dire
En fait on a quelque chose, mais faute de temps et parce que je ne fais pas de F3K, ce n'est pas encore valider. Mais cela viendra
maume gilles
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Jeu 21 Jan - 13:48
Merci pour ces reponses.
Je vais tester les 2 possibilités :
confectionner moi meme le regulateur , ne faut il pas rejouter un condensateur en entrée et un autre en sortie?
Je me laisserai bien tenter par le modele PLD-BAC-004 qui nous averti que la tension du lipo 2s est trop basse , on doit entendre le buzzer jusqu'a une trentaine de metre , en f3k on est souvent tres proche du modele.
Erik je compte utiliser un lipos 2s 360mA cela donne quelle autonomie d'apres ton experience?
Gilles
Erik Richards
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Jeu 21 Jan - 15:18
J'utilise des 240mah et je n'ai jamais rechargé en concours, donc ca fait min 1h mais je pense que ca peut encore plus.
Justement comme on a un specialiste en electronique, qu'en est-il des autonomies justement? Un 2s 300mah régué et un nimh 4s 300mah est-ce qu'on a la meme autonomie?
Serge Delarbre
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Ven 22 Jan - 11:49
Je fais un petit topo au propre et je répond
Erik Richards
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Ven 22 Jan - 13:36
Super cheers
Serge Delarbre
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Sam 23 Jan - 22:54
Pour faire simple, on raisonne sur les valeurs nominales et
sur une utilisation de la quantité d’énergie disponible de 100% :
NiMh 4 éléments (4 *
1.2 = 4.8V) 300mAh
Quantité d’énergie disponible : 4.8 * 300 = 1440 mWh.
LiPo 2S (2
* 3.7 = 7.4 V) 300 mAh
7.4 * 300 = 2220 mWh.
Puissance dissipée par le régulateur 5 V : (7.4-5) * 300
= 720 mWh.
Quantité d’énergie disponible : 2220 – 720 = 1500 mWh.
Maintenant je ne connais pas la consommation moyenne d’un F3K. Mais par extrapolation à la louche
avec un F3F (environ 1500 mWh en condition course), je dirais 800 mWh. Donc, l’autonomie
doit être du genre :
1440 / 800 = 1.8 = 1h48 @ 4.8 V.
1500 / 800 = 1.875 = 1h52 @ 5 V.
maume gilles
MessageSujet: retour d'experience PLD-BAC-004 et lipo 360ma 2s sur aspirin   Mar 23 Fév - 17:32
Citation:
J'ai maintenant quelque sceance de vol avec ce materiel sur un aspirin.
Le lipo est un rhino 360mA 20c.
Apres 1h30 de vol la tension en charge de l'accu etait = 7.6v
a 2h de vol U= 7.49V
D'apres ce que j'ai compris , le buzzer du regulateur est activé a partir de 7.2v .
A 7.2v l'accu n'est pas totalement dechargé ( je crois que s'est 3v/element pour les lipos) , je suppose que le regulateur en dessous de cette tension ne plus apte a fournir du 5v en sortie.
En resumé , vu ce test l'autonomie doit etre comprise entre 2h30 et 3h.
L'accu fait 22g et le regul 6g = 28gr
je vais recharger ce soir et l'accu sera operationnel de suite apres ou meme dans un mois!
Gilles
valentin
Nombre de messages: 503
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Mar 23 Fév - 17:38
ET oui !!
c'est ca qui et bon !!
VIVE LE LIPO
Nombre de messages: 1939
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Ven 26 Fév - 0:16
Erik
Salut Erik,
ben justement, quand je vois les spec du truc :250mA constant supply, 500mA for 1 minute, 1A for 10 seconds
Avec 4 servos je serais pas tranquille ... Un servo de F3K consomme pas trop (encore ca dépend lesquels), mais 4 en meme temps on a aps bcp de marge tout de meme.
Un D60 ca va de 150mA au repos a 450mA au couple max et meme un peu plus de 550 pour le courant max.
Erik Richards
MessageSujet: Re: regulateur tension pour f3k - PLD-BAC-004   Ven 26 Fév - 8:13
Erik
Salut Erik,
C'est marrant mais tu fais une erreur, à mon avis il y a un soucis avec les courbes servormances au niveau du zero couple, ca ne dois pas consommer autant au repos à mon avis olivier ramène ca à une droite mais c'est impossible que ca consomme autant au repos. La preuve est l'exemple de gilles ci dessus, si on calcule comme toi les 4 servos consomment 370mah au repos (sans la consommation du récepteur), ca voudrait dire qu'il aurait moins de une heure d'autonomie, pourtant il nous explique qu'il a entre 2h30 et 3h
Je peux te dire que ca marche et on est nombreux à l'utiliser en F3K dans le monde...
Erik
Même pas peur
Page 1 sur 6Aller à la page : 1, 2, 3, 4, 5, 6  Suivant
» alimentation haute tension - annexe 3
» Détachant pour le linge
» Musique pour tous...
» Pour apprendre la dentelle
» Pepakura pour le cosplay .
