 Proposition de Reglement F3B-e
PatrickM
Nombre de messages : 111
MessageSujet: Proposition de Reglement F3B-e   Jeu 1 Fév 2018 - 6:47
Voici un proposition de règlement pour le F3B-e réalisé par Ralf Decker.
Tout n'est pas figé, il reste ouvert a discussion sur notamment les caractéristiques du moteur et les pénalités fonction de l'altitude et autres.
Vous pouvez avoir le document complet ICI avec ses commentaires.
Mise a jour au 14/02/18
VOLUME F3 SOARING
PART FIVE - TECHNICAL REGULATIONS FOR RADIO CONTROLLED CONTESTS
5.8. CLASS F3B-e – MULTI-TASK GLIDERS WITH ELECTRIC MOTOR
5.8.1. General Rules
5.8.1.1. Definition of a Radio Controlled Glider with electric motor
Model aircraft which is provided with an electric motor. Model aircraft with variable geometry or area must comply with the specification when the surfaces are in maximum and minimum extended mode. The model aircraft must be controlled by the competitor on the ground using radio control. Any variation of geometry or area must be actuated at distance by radio control.
5.8.1.2. Prefabrication of F3B-e Model Aircraft
Paragraph B.3.1 a) of Section 4B (Builder of the Model aircraft) is not applicable to class F3B-e.
5.8.1.3. Characteristics data of Radio Controlled Gliders F3B-e
Minimum wing-loading 35 g/dm²
Maximum wing-loading 75 g/dm²
Maximum flight mass 5 kg
Maximum energy 400 Wmin
Maximum “Average input performance” 800 W
Battery Any type of rechargeable batteries
Motor Any type of motor
Minimum spinner radius 7.5 mm (see template)
TEMPLATE FOR SPINNER RADIUS
5.8.1.4 Technical equipment
a) Each model must be fitted with an approved Logger (LOG) in accordance with the Technical Specification published in F3B-e LOG Technical Documentation.
b) The LOG must be approved by the EDIC (ELECTRONIC DEVICES IN COMPETITIONS WORKING GROUP).
c) The LOG is located in the electric circuit between the battery and the motor.
d) Installation of the LOG in the model shall be in accordance with the requirements as detailed in the Technical Guidance Documentation.
e) Proper operation of the LOG including any associated display and its compatibility with other control equipment installed in the model is the responsibility of the individual competitor.
f) To facilitate initial technical processing, all LOGs must be easily removable for compliance checking.
The receiver command signal connection to the LOG must be easily accessible so that at any time during the competition the organisers have the option of installing a monitoring LOG via a branching Y lead.
g) To enable the timekeeper to record data required for scoring purposes there must be easy access to the display or the connector for a plug in display. It must not be necessary to disconnect the LOG from the receiver or to remove it from the model,
h)The use of an additional extension cable is permitted for connecting the display. It is the responsibility of the competitor to ensure that any incorrect connection does not result in damage to the LOG or the display.
i) The functions of the LOG is to record “altitude”, “voltage” and “current “and to represent “altitude”, “amount of energy” and “average performance” at a display.
j) The motor can be stopped by the pilot or is stopped automatically if the energy-limit is reached.
If the energy exceeds 400 Wmin there is a deduction of 0,5 points / 1 Wmin.
k) If the “average performance” exceeds 800 W there is a deduction of 1 point / 10 W.
l) LOG data must be shown to the official immediately after the flight.
5.8.1.5. General requirements
a) No fixed or retractable arresting device (i.e. bolt, sawtooth-like protuberance, etc.) is allowed to slow down the model aircraft on the ground during landing.
The underside of the model aircraft must not have any protuberance other than
b) Any transmission of information from the model aircraft to the competitor is prohibited, with the exception of signal strength and voltage of the receiver battery. Any use of telecommunication devices (including transceivers and telephones) in the field to communicate with competitors, their helpers or team managers while doing the competition task is not allowed.
c) The competitor may use a maximum of three (3) model aircraft in the contest. All exchangeable parts (wing, fuselage, tail planes, joiner) must be marked uniquely and in a way that does not allow replication of this mark on additional parts.
d) The competitor may combine the parts of the model aircraft during the contest; provided the resulting model aircraft used for flight conforms to the rules and that the parts have been checked before the start of the contest. See also 5.8.2.1.
5.8.1.6. Competitors and Helpers
The competitor must operate his radio equipment personally. Each competitor is permitted up to three (3) helpers, including the team manager, who must not give any turning signals near base B during tasks B and C.
5.8.1.7. Definition of an Attempt
a) For each task (ref. 5.3.2.1.), during the working time allocated, the competitor is entitled an unlimited number of attempts. An attempt starts when the model aircraft is released from the hands of the competitor or his helper(s) under the power of the electric motor. No change of model aircraft or parts of the model aircraft is allowed after starting the first attempt.
b) The competitor is entitled to a new working time period if any of the following conditions occur and are duly witnessed by an official of the contest:
i) his model aircraft in flight collides with another model aircraft in flight, or another model aircraft in the process of launch (released for flight by the competitor or his helper). Should the flight continue in a normal manner, the competitor may demand that the flight in progress be accepted as official, even if the demand is made at the end of the original working time
ii) his model aircraft in the process of launch collides with another model aircraft also in the process of launch (released for flight by the competitor or his helper), or with another model aircraft in flight. Should the flight continue in a normal manner, the competitor may demand that the flight in progress be accepted as official, even if the demand is made at the end of the original working time
iii) the flight has not been judged by the fault of the judges or timekeepers.
iv) in the case of an unexpected event, outside the competitor’s control, the flight has been hindered or aborted.
c) For all cases described above the competitor may demand that the flight in progress in which the event occurred will be accepted as official. Note is made that in the event the competitor continues to launch or does a re-launch after clearing of the hindering condition(s) he is deemed to waive his right to a new working time.
d) The competitor has the right to change his model during a current round and this is not withstanding rule 5.8.2.1. if:
1. his model collides with another model in flight; he has the right for a reflight, but his model is not reparable in time.
2. his model has landed (final or intermediate landing) and is damaged by a landing model of another competitor and the model is not reparable in time.
3. in the case of 1) or 2) above, once the competitor has exercised his right to change his damaged model aircraft, that model must not be used in any subsequent task(s) in the current round, with the exception stated in paragraph 5.8.1.3.f).
e) In case of additional attempts in task A (Duration) during a round or task B (Distance) during a round, the competitors entitled to that additional attempt must fly within a group that is not complete in number or in one or more groups newly formed.
5.8.1.8. Definition of the Official Flight
The official flight is the last flight performed during the working time.
5.8.1.9. Cancellation of a Flight and Disqualification
a) Unless otherwise specified a flight in progress will be annulled for an infraction of any rule. In the case of intentional or flagrant violation of the rules, in the judgement of the Contest Director, the competitor may be disqualified.
b) The flight in progress will be penalised with 100 points if the model aircraft loses any part either during the launch or the flight. The loss of any part in a collision with another model aircraft or
during landing (i.e. in contact with the ground) is not taken into account. The penalty of 100 points will be a deduction from the competitor’s final score and shall be listed on the score sheet of the round in which the penalisation was applied.
c) The competitor is disqualified if the model aircraft in flight is controlled by anyone other than the competitor.
d) If the model aircraft touches either the competitor or his helper during landing manoeuvres of task A, no landing points will be given.
5.8.1.10. Organisation of Starts
a) The competitors shall be combined in groups with a draw, in accordance with the radio frequencies used, to permit as many flights simultaneously as possible. Incomplete teams may be to their request combined into a working team. The draw is organised in such a way that there are no competitors of the same working team in the same group. At World and Continental Championship the reigning champion, if participating outside the national team, may join his national team to form a working team.
b) The composition of the groups must be changed every round in order to have different combinations of competitors. For task A (duration), there must be a minimum of five competitors in a group. For task B (distance) there must be a minimum of three competitors in a group. For task C (speed) a group may consist of a minimum of eight competitors or all competitors.
It is preferable for the organiser to orientate the starting order for task C at the inverted ranking calculated out of the results of all tasks flown until that moment. For the first round the starting order for task C should always be identical with the starting order of task A. Alternatively the organiser may use the task A starting order in subsequent task C rounds.
c) The result of a group is annulled if only one competitor has a valid result. In this case, the group will fly again and the result will be the official result.
d) The flying order of different groups is established with the draw too. A different starting order shall be used for each round.
e) The competitors are entitled to 5 minutes of preparation time before the starter gives the order to count off working time.
5.8.1.11. Organisation of Contests
a) For transmitter and frequency control see Section 4B, para B.10.
b) The official will issue the transmitter to the competitors only at the beginning of their preparation time, according to 5.8.1.8.
c) Sighting apparatus, winches or any device constituting an obstacle, should be placed on Base A and Base B, a minimum of 5 metres from the safety line for task C. Apparatus for judging the safety plane in task C shall be placed a minimum distance of 5 metres from Base A or B outside the course.
d) The contest director must inform without delay the competitor and/or his team manager about any decision taken, eg in the case of a re-fly, a penalty etc.
5.8.1.12. Safety Rules
a) The organiser must clearly mark the boundary between the landing area and the safety area assigned for other activities. (See sketch “F3B / F3B-e flying field layout” page 10)
b) After release of the model aircraft from the hand of the competitor or helper, any contact of the model aircraft with any object (earth, car, stick, plant, tow-line, etc) within the safety area will be penalised by 300 points, except in the circumstances described in paragraph 5.8.1.5 b) items 1,
2, 3, and 5. Contact with a person within the safety area will be penalised by 1000 points. The number of contacts during one attempt does not matter (maximum one penalty for one attempt). The penalty will be a deduction of 300 or 1000 points from the competitor’s final score and shall be listed on the score sheet of the round in which the penalisation was applied.
5.8.1.13. Weather Conditions / Interruptions
a) The maximum wind speed for F3B contests is twelve (12) m/sec. The contest has to be interrupted or the start delayed by the contest director if the wind speed exceeds twelve (12) m/sec measured three (3) times for at least twenty (20) seconds in a time interval of five (5) minutes two (2) metres above the ground at the start and landing area.
b) In the case of rain, the contest director can interrupt the contest during task A and task B. When the rain stops, the contest starts again with the group that was flying, which receives a re-flight.
c) In the case of rain, the contest director must interrupt the contest during task C. When the rain stops the contest start again with the pilot that was flying, which receives a re-flight. The whole group of task C must be divided in three (3) or four (4) groups depending on the total number of competitors before the task starts. If the weather is stable only one group is evaluated; if the competition must be interrupted more than fifteen (15) minutes, then the interrupted group must start from the beginning and the results are evaluated for each group.
5.8.2. RULES FOR MULTI-TASK CONTESTS
5.8.2.1. Definition
a) This contest is a multi-task event for radio controlled gliders with electric motor, which includes three tasks:
A) Duration
B) Distance
C) Speed
b) The combination of task A, B and C constitutes a round. A minimum of two rounds must be flown. Except at World and Continental Championships the last round may be incomplete, i.e. only one task or any combination of two tasks. In the case of a World Championships each competitor is entitled a minimum of five rounds subject to the provision of rule B.15, Section 4B.
At the discretion of the organiser any task may be flown first in a scheduled round. In the case of unstable weather conditions, lack of time or technical issues it is possible fly task A or B of the following round before the task C of the current round. No other change of the schedule is allowed. The scheduled task must be completed. If the model is damaged during the predrawn task (A or B) the competitor is entitled to change the model for task C of the previous round.
c) Any single round must be completed with the same model aircraft, without any change of parts. Only the addition of ballast (which must be located internally in the model aircraft and with which the model aircraft must conform to rule 5.8.1.3.) and/or change of angles of setting are allowed.
d) Variation of geometry or area is allowed if actuated at distance by radio control.
5.8.2.2. Launching / Relaunching
a) All launching shall take place in an area as designated by the organiser with provisions made for launching into the wind.
b)The landing for a relaunch has to take place in an area designed by the contest director; out of safety reasons it´s not allowed catching the model. The restart must be done behind base A in direction to base B.
The reset of the logger must be done manually; a reset via transmitter is forbidden“
5.8.2.3. Task A-Duration
a) This task must be completed within 12 minutes from the order of the starter, including the rise time.
b) One point will be awarded for each full second from the time the motor has stopped to the time the model aircraft comes to rest on the defined flying site, up to a maximum of 600 points (i.e. 10 minutes maximum), for each full second of flight within the working time; if the model does not land on the defined flying site the whole flight is zero. No points will be awarded for flight time in excess of working time
c) One point will be deducted for each full second flown in excess of 600 seconds (10 minutes).
d) Additional points will be awarded for landing, depending upon distance from the spot marked by the organiser, according to the following table:
Distance from spot (m) Points Distance from spot (m) Points
1 100 9 60
2 95 10 55
3 90 11 50
4 85 12 45
5 80 13 40
6 75 14 35
7 70 15 30
8 65 over 15 0
The distance is measured from the model aircraft nose (spinner) when at rest to the centre of the spot.
No points will be awarded for the quality of landing.
No landing bonus will be awarded if the flight time exceeds 630 seconds.
The measured distance is rounded to the nearest higher metre.
e) For model aircraft still in the air when the 12 minutes expire, the elapsed flight time only will be taken into consideration for scoring, without any additional points for the precision landing.
f) A classification based on decreasing number of points awarded will be compiled, called "Partial Score A" - see 5.8.2.6.
g) One of the functions of the LOG is to record and display the maximum altitude attained (start altitude) above a ground level reference between the instant of motor start and ten (10) seconds the motor is stopped.
h) The recorded start altitude in metres shall be rounded down to the nearest metre.
i) Each metre of the recorded start altitude results in a deduction of half (0,5) a second / metre up to 220 metre and three (3) seconds / metre above 220 metre.
j) Where the score is negative (below zero), a zero score will be recorded.
b) Proper operation of the LOG including any associated display and its compatibility with other control equipment installed in the model is the responsibility of the individual competitor.
c) To facilitate initial technical processing, all LOGs must be easily removable for compliance checking.
5.8.2.4. Task B - Distance
a) The model must past Base B either during motor run or after motor cut-off, in order to legitimate the flight.
b) This task must be completed within 7 minutes from the order of the starter, including the rise time. The trial begins only after the motor has stopped.
c) When the model aircraft, in flight, first crosses Base A (imaginary vertical plane) in the direction to Base B, the actual flight time of 4 minutes maximum starts, during which time the model aircraft must complete as many legs as possible from the starting Base A to Base B and conversely.
d) A visual system or a combined audiovisual system announces to the competitor when his model aircraft crosses the Base A or Base B (imaginary vertical planes). The absence of a signal will indicate that the model aircraft has failed to correctly cross the base. The instruments used to check the crossing of the vertical planes must assure the parallelism of such planes. Timing and signalling shall occur when any part of the complete model aircraft in flight crosses the base. If an audiovisual system is used, signalling is also valid when the audio system fails.
e) The models will be identified by flags of different colours for each competitor in the group. When the competitor intends to start his helper waves the flag; when the model is identified by the associated helpers at base A and base B they wave the flag with the corresponding colour as well. At that moment the pilot can launch.
The competitor must stay within a distance of 10 metres either side of Base A during the timed flight.
f) For a model aircraft which lands within 4 minutes flight time only the full 150 metre legs will be counted. For model aircraft still in the air when the 4 minutes flight time or 7 minutes expires, whichever comes first, only the completed legs at that moment will be taken into account.
g) After having completed the task, the model aircraft must land on the defined flying site outside 018.the safety area(s) otherwise the flight is zero.
h) A classification based on decreasing number of total flown legs during the flight time will be compiled, and points given as described in 5.8.2.6., thus establishing the “Partial Score B".
5.8.2.5. Task C – Speed
a)The model must past Base B either during motor run or after motor cut-off, in order to legitimate the flight.
b) This task must be completed within 4 minutes, from the order of the starter including. The model aircraft must start the task at Base A within one minute after the motor has stopped. If the one minute period expires before the model aircraft has crossed Base A for the first time, flying from Base A to Base B, then the model aircraft must be landed and re-launched within the original working time period.
c) The task consists of flying the distance starting from Base A, to Base B, and conversely, four legs in the shortest possible time.
d) The flight time is recorded to at least 1/100 sec when in flight the model aircraft first crosses Base A at the predetermined side of the safety-plane and completes four legs of the 150 metre course.
e) An audio system will inform the competitor when the model aircraft crosses the Base A or Base B (imaginary vertical planes). The absence of a signal will indicate that the model aircraft has failed to correctly cross the Base. The instruments used to check the crossing of the vertical planes must assure the parallelism of such planes. The signal is given when any part of the complete model aircraft in flight crosses the base. The source of the signal (horn, loudspeaker) must not be further
then 30 metres away from the intersection of base A and the safety plane.
f) During the timed flight the competitor must stay within a distance of 10 metres either side from Base A.
g) After having completed the task, the model aircraft must land on the defined flying site outside the safety area(s) otherwise the flight is zero.
h) Model aircraft which come to rest before having completed the task will score zero.
i) During task C the timed flight shall take place to one side of the safety plane, whilst all judges/time-keepers shall remain on the other side of the safety plane. The side which is to be flown shall be indicated by the organisers taking into account the direction of the sun, etc.
The flight will be penalised with 300 points, when sighted by means of an optical aid, the safety plane is crossed by any part of the model aircraft. The instrument used to check the crossing of the vertical safety plane must also assure that the safety plane is orthogonal to Base A and Base B. The penalty of 300 points will be a deduction from the competitor’s final score and shall be listed on the score sheet of the round in which the penalisation was applied.
j) After the stop of the motor, when the model aircraft has crossed Base A for the first time, flying in the direction from Base A to Base B, no further attempt is permitted unless the competitor signals his intention to re-launch before Base A is crossed.
k) A classification based on increasing times to complete the four 150 metre legs will be compiled, and points given as described in 5.8.2.6., thus establishing "Partial Score C".
5.8.2.6. Partial Scores
a) Partial Score for Task A for each competitor is determined as follows:
Partial Score A = 1000 x P1 / Pw
P1 ≤ 220 m = Flight [s] – 0,5 x height-start altitude [m] (see 5.8.2.3.h)
P1 > 220 m = Flight [s] – ((220x0,5) +(3 x (height-start altitude -220))
PW = points of the winner in the related group.
b) Partial Score for Task B for each competitor is determined as follows
Partial Score B = 1000 x D1/DW
Where D1 = distance covered by the competitor as for 5.8.2.4
DW = distance covered by the winner in the related group.
c) Partial Score for Task C for each competitor is determined as follows
Parrtial Score C = 1000 x TW/T1
Where T1 = time of the competitor as for 5.8.2.5.
TW = time of the winner in the related group.
5.8.2.7. Total Score
The competitor’s Total Score for each round is compiled by adding the Partial Scores of all tasks.
5.8.2.8. Classification
If only five rounds are flown, the competitor’s classification is determined by the sum of all Total Scores for each round. If more than five complete rounds are flown the lowest partial score of each task with more than five results is omitted from the sum of all partial scores. To decide the winner when there is a tie, the two (or all who have the equal score) competitors will fly an additional round (three tasks).
5.8.2.9. Site
The competition must be held at a site having reasonably level terrain, with a reasonably low probability of slope or wave soaring.
Flying Field Layout
For a combined F3B / F3B-e competition the start of the F3B-e models takes place at the winch-line.
For a F3B-e competition the launch takes place at the launch-line (former winch-line); the safety area between the former winch-line and the turn-around-line can be used for landing.
R. Decker
Nombre de messages : 1038
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 1 Fév 2018 - 7:24
Une très bonne initiative. De quoi relancer le F3B tout en préservant son côté technique.
Merci de partager Very Happy
PatrickM
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 10:10
La dernière mouture du règlement F3B-e qui sera présenté à la CIAM prochainement.
Quo Vadis F3B_englisch_actuell.pdf
Class F3B-e_06.02.2018_komplett_Kommentar_GER.pdf
Le lien et le règlement est également mise à jour dans le premier message.
Bonne lecture.
jm.leprovost
Nombre de messages : 539
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 13:29
Bonjour ,
Ce serais cool Very Happy d'avoir une synthèse en français des spécificités de la formule F3B-E pour les nuls en anglais comme moi et surement d'autres ........ Suspect
PatrickM
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 15:29
Voila Jean Mi:
Pour résumer le F3B-e :
Les épreuves sont les mêmes que pour le F3B, durée, distance et vitesse.
La montée se fait au moteur électrique à la place du treuil.
Les planeurs sont les mêmes, point de vu caractéristiques que les F3B classiques.
La masse mini est de 35 g/dm² soit environ 2.2/2.3 Kg
La masse max 75 g/dm² soit environ 4.5 kg
Un contrôleur de type Alti V4 avec un programme adapté coupera le moteur après une consommation de 400 Wmin, ce contrôleur donnera également la performance moyenne du moteur qui est limité à 800 W (pénalité en cas de dépassement).
Le moteur coupé il ne sera plus  possible de le redémarrer.
La monté doit se faire de la ligne de treuil base A vers la Base B, un passage à la base B est obligatoire pour valider le vol.
Les redéparts sont possibles après atterrissage dans une zone défini et une réinitialisation manuelle du moteur au sol.
Les temps de travail sont les mêmes soit:
12 minutes pour la durée et il faut faire 10 minutes au plus près possible avec atterrissage de précision (comme en F3B). A noter que pour la durée le gros changement est que le principe du F5J est appliqué pour la hauteur de coupure moteur et cette Hauteur rentre dans le calcul des points. Le temps de vol démarre à la coupure moteur.
Pour la Distance le temps de travail est de 7 minutes et temps de vol max pris en compte pour la distance 4 minutes (comme en F3B).
Pour la vitesse le temps de travail est de 4 minutes, pas de redépart possible si l’on passe la Base A vers la B (comme en F3B).
A noter que à partir de cette année pour le F3B ou F3B-e la zone d’atterrissage possible est défini au briefing. Atterrissage hors zone (notamment hors terrain = pénalité).
Une traduction complète sera faites après l'adoption de cette catégorie.
Nombre de messages : 3483
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 15:57
Patrick,
Ouahhhh c'est énorme comme puissance disponible pour une montée, car avec maximum 800Watts en instantanée et une énergie maximum de 400Wmin, cela veut dire que tu pourrais avoir une motorisation qui absorbe 790 Watts en pointe (soit environ 80A en 3SLipos et environ 60A en 4S lipos).
ce qui veut dire que l'on pourrait avec ce type de motorisation mettre 30 Secondes de moteur plein gaz (avec 800Watts) tongue
Avec cette puissance sur un F3B moderne de 3Kgr , on peut monter entre 370 et 400 mètres je pense, sans souci.
Le problème c'est qu'un moteur de Ø28mm et 200gr qui passe 800Watts pendant 30 secondes sans interruption va commencer à sentir le chaud scratch
Pour infos sur mon SHOOTER électrique, avec environ 620 Watts , je monte à 230m en moins de 20 secondes, sans vent (avec ~ 300 gr de ballast)
PatrickM
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 16:10
Cette puissance a été retenue pour avoir une hauteur d'environ 250 mètres pour la vitesse.
Pour la distance la hauteur sera fonction du choix du pilote sur la masse du planeur.
Pour la durée pas de soucis il faudra couper en dessous de 220 mètres pour ne pas augmenter fortement les points de pénalités par mètres.
0,5 points par mètre jusqu'a 220 mètres et 3 points par mètre au dessus.
Rien n'oblige d’avoir 800 w (c'est une limite) avec moins de puissance la montée sera juste plus longue.
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 16:23
Patrick,
Dans mon cas sur mon vieux Shooter, ballasté à plus de 3Kgr, je suis déjà à 250m en moins de 25 secondes et avec environ 620/ 630 Watts maxi.
A mon avis il va y avoir des pilotes qui vont partir de 300 mètres voir plus avec un F3B de 3,5 Kgr en vitesse tongue
(Surtout avec un bon lanceur au départ)
PatrickM
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 16:53
C'est ce que l'on a déjà aujourd'hui avec des F3B par bonnes conditions.
Il faut que les performances en vitesse soit au moins aussi bonnes, si non cela n'intéressera personne.
Cette puissance est également nécessaire pour un décollage en toute sécurité a plein charge.
Il y aura peut être des ajustements avec l’expérience du terrain.
jm.leprovost
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 18:19
Super Patrick cheers un résumé comme ça me va très bien tiptop
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 18:45
Patrick,
Les 800 Watts maxi ne me dérange pas et me semble même être une bonne valeur max !
Mais les 400Wmin/ montée c'est déjà beaucoup et cela risque de faire des écart entre ceux qui vont pouvoir avoir des bons Yeux et les autres..........
Il faut voir sur le terrain comme tu dis.
Nombre de messages : 728
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 18:57
Salut Patrick,
Je lis tout ça avec intérêt !
Mais je n’ai pas très bien compris certains points de la proposition de règlement. Tu vas surement m’expliquer :
Pour la durée, OK, comme en F5J avec une pénalisation par altitude. Attention, je crois qu’il y a une erreur ! Ralf dit :
Mais ensuite il est ecrit:
P1 > 220 m = Flight [s] – 3 x height-start altitude [m] (see 5.8.2.3.h)
Ça veut dire que si tu dépasses 220m c’est 3s/m depuis le sol ?????? En F5J c’est 200m mais les 3s/m sont pour les mètres au-delà de 200m. En dessous ça reste 0,5s/m. Si on veut faire comme en F5J, ca serait P1 > 220 m = Flight [s] – ((220x0,5) +(3 x (height-start altitude -220))
Il y a-t-il erreur ou est-ce volontaire ???
Pour la distance et la vitesse, si je comprends bien, il n’y a pas de limite autre que la performance et l’énergie dépensée…
Comme Stéphane, je trouve ça beaucoup cette limite de 800W / 400W.min… Ça me parait disproportionné par rapport aux disons 250/260 d’un treuillage moyen.
Pour info, avec mon Shooter électrifié qui collerait parfaitement au règlement (2kg400 à vide/3kg650 full ballast, motorisation 700W environ en 4S) je dois pouvoir monter à plus de 300m avec 400W.min De mémoire j’ai les taux de montée suivants : 9m/s full ballast, 12m/s à mi ballast et 15m/s à vide. Et le règlement me permettrait un peu plus de 30s de moteur.
A l’occasion je remesurerai pour confirmer.
PatrickM
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 19:36
Nicolas,
Tu as raison il doit y avoir une erreur.
Je vais en parler à Ralf.
400wmin c'est peut-être trop mais c'est un départ.
Il sera facile de modifier le programme du V4 au besoin (350wmin par exemple).
Ne pas oublier qu'il faut revenir de la base B pour prendre le départ, donc perte d'altitude.
MessageSujet: Re: Proposition de Reglement F3B-e   Jeu 15 Fév 2018 - 21:45
Salut Nicolas,
Merci pour ta remarque et pour ton retour d'expérience, cela coïncide avec ce que je pensait......
Patrick,
Je ne comprend pas comment avec un appareil de type ALTI V4 on va pouvoir contrôler et mesurer la puissance maximum et l’énergie maxi par montée scratch sachant que ce type d'appareil est monté entre le contrôleur et le récepteur .
Il va falloir monter un dispositif du type de celui utilisé en F5B et qui est en série sur la chaine de puissance............... enfin il me semble.
Sinon, pour la distance , il faut prévoir de repartir 2 fois, soit trois montée de suite au moteur à environ 250m, donc il faudra quand m^me un peu d'autonomie:
Si on calcul cela donne minimum des 1800 Mah en 3S sous 78A et des 1300Mah en 4S sous 59 A environ pour avoir un peu moins des 400Wmin.
Voilà
PatrickM
MessageSujet: Re: Proposition de Reglement F3B-e   Ven 16 Fév 2018 - 13:47
Bien vu Nicolas, c'etait bien une erreur.
Cela va être corrigé.
Roland Henninot
Nombre de messages : 382
MessageSujet: F3B-E   Sam 17 Fév 2018 - 11:51
Salut Patrick,
Merci pour les infos du nouveau règlement F3B-E,
voici la liste du matos utilisé en F5B je pense qu'il sera équivalant au F3B-E
1 x UNILOG 2
1 x UNILOG Stromsensor le capteur pour mesurer la puissance (soit le 80A ou le 150A)
1 x Câble USB Interface (pour paramétrer l'UNILOG 2)
ou 1 x UNIDISPLAY
il existe des câbles adaptateur pour utiliser la télémétrie en fonction des marques de radio
a connecter directement sur le récepteur, voir la documentation SM-MODELLBAU,
pour Futaba et Spectrum des câbles spécifique a commander voir le lien ci-dessous,
pour Jeti un simple câble prise universel (servos servos) suffit et c'est très facile a utiliser avec la Radio JETI,
https://www.sm-modellbau.de/UniLog-2-und-Zubehoer
un investissement supplémentaire mais bien pratique a utiliser pour mesurer la puissance!!!
Roland
» Proposition de modification du règlement F5J
» REGLEMENT DES DEBATS
» SOLDES (proposition sujet unique)
» NOUVEAU REGLEMENT. A LIRE AVANT DE POSTER, MERCI!
» proposition de jeu: Une tombola
