 Mesure vent maxi 12ms
Nombre de messages : 2091
MessageSujet: Mesure vent maxi 12ms   Mar 2 Mai 2017 - 14:50
J'aimerais avoir des informations concernant la limite FAI de vent
Comment dois ce faire la Mesure?
A quelle hauteur
Pendant combien de temps
Et que faire si la limite est dépassé. ? Revol.interruption
Et quand peut on reprendre?
bechepay_gilles
Nombre de messages : 666
MessageSujet: Re: Mesure vent maxi 12ms   Mar 2 Mai 2017 - 15:18
Salut FRED
tout est là : General_Rules_17.pdf et comme rien de spécifié dans les règles F5J ce sont donc les règles générales qui s'appliquent =>
Interruption
a) The contest should be interrupted or the start delayed by the contest director in the following circumstances and in other exceptional circumstances decided by the contest director:
i) Unless specified otherwise in the rules for a category or a particular class, the wind is continuously stronger than 12 m/s measured at two (2) metres above the ground at the starting line (flight line), for at least one minute
ii) The visibility prohibits proper observation of the models (especially in case of F/F or R/C contest) or due to atmospheric conditions it would be dangerous to continue the contest.
iii) It is necessary to reposition the starting line. This may only take place between rounds, or between tasks or groups in F3B and between rounds or groups in F3J.
iv) The prevailing conditions are such that they may lead to unacceptable sporting results.
v) For F3A, F3M, F5A, F3C, F3N, F4C, F4H, F3D and F5D, when the sun is in the manoeuvring area.
vi) Any incident affecting safety or requiring access for emergency services.
b) In the event of an interruption during a round, the contest director must decide the action to be taken to complete, repeat, or cancel the round. The remainder of the round may be completed as soon as conditions allow, with adequate notice given to all competitors and team managers.
In the cases described, the organiser is not obliged to return the entry fee nor repeat the contest. The results will be based on the scores of the finished rounds.
An interrupted contest can be extended if the requirements of C.17.1 are met.
mais 12m/s pendant 1min cela fait souvent des rafales à plus de 60km/h et généralement tu n'auras plus beaucoup de compétiteurs prêts à en découdre sauf en concours international.
@pluche
MessageSujet: Re: Mesure vent maxi 12ms   Mar 2 Mai 2017 - 15:45
Ok donc 12ms sur 1minute à 2m sol
bechepay_gilles
MessageSujet: Re: Mesure vent maxi 12ms   Mar 2 Mai 2017 - 15:50
attention il s'agit de la vitesse mini (continuously stronger) sur 1 min et pas de la vitesse moyenne lutin lutin lutin
Nombre de messages : 2057
MessageSujet: Re: Mesure vent maxi 12ms   Mar 2 Mai 2017 - 16:16
Et pour ceux qui veulent le document en entier, c'est ici : http://www.fai.org/ciam-documents
en bas de la liste des documents à :
Sporting code section 4 : Aeromodelling
Document à télécharger (pdf)
Sporting code section 4 - CIAM General Rules
Chapitre C.17 Page 42
et avec gogol en français ça donne cela :
A) Le concours doit être interrompu ou le début retardé par le directeur du concours dans les circonstances suivantes et dans d'autres circonstances exceptionnelles décidées par le directeur du concours:
I) Sauf indication contraire dans les règles pour une catégorie ou une classe particulière, le vent est continuellement plus fort que 12 m / s mesuré à deux (2) mètres au-dessus du sol à la ligne de départ (ligne de vol) pendant au moins une minute
Ii) La visibilité interdit l'observation correcte des modèles (surtout en cas de concours F / F ou R / C) ou en raison de conditions atmosphériques, il serait dangereux de continuer le concours.
Iii) Il est nécessaire de repositionner la ligne de départ. Cela ne peut avoir lieu que entre des tours ou entre des tâches ou des groupes dans F3B et entre des rondes ou des groupes dans F3J.
Iv) Les conditions préalables sont telles qu'elles peuvent conduire à des résultats sportifs inacceptables.
V) Pour F3A, F3M, F5A, F3C, F3N, F4C, F4H, F3D et F5D, lorsque le soleil se trouve dans la zone de manœuvre.
Vi) Tout incident affectant la sécurité ou nécessitant un accès aux services d'urgence.
B) En cas d'interruption lors d'une ronde, le directeur du concours doit décider de l'action à entreprendre pour compléter, répéter ou annuler le tour. Le reste du cycle peut être complété dès que les conditions le permettent, avec un avis adéquat accordé à tous les concurrents et aux gestionnaires d'équipe.
Dans les cas décrits, l'organisateur n'est pas obligé de renvoyer les frais d'inscription ni de répéter le concours. Les résultats seront basés sur les scores des cycles terminés.
Un concours interrompu peut être prolongé si les conditions de C.17.1 sont respectées.
Very Happy
» conditions de vents maxi
» Connaitre la Vitesse Maxi de son rc à moidre coût
» Du vent dans mes mollets - Moussafir / Mam'zelle Roüge
» moteur compound de GRAINE AU VENT
» Le Vent de Feu
